Hi there,
Not sure what the error may be, have added the You Tube Link on one of the Gallery pages and is not playing the video at all. Error message appears:
"An error occurred,please try again later"
Have trial another video on YouTube and this seems to work.
Thanks,
Wendy
Show your link please. write it here withou
http://. Also check how youtube link should look http://apollo13.eu/docs/beach/#!/image_sizes_video_support_and_others_video_audio_supportWith regards.
Please check fayemosshammer.com/?gallery=music-work-1
I have also used the correct links as suggested.
Thanks,
Wendy
http:// www.youtube.com/watch?v=t3gIIq3fqAw&list=PL0zJKaKW7nyoJDFcqtnV9qTkHJa8z5pmYTry removing
&list=PL0zJKaKW7nyoJDFcqtnV9qTkHJa8z5pmY.Unfortunate it looks that lightbox plugin is sensitive for that extra data.
Have tried this and only one of four videos work using the links suggested. Please can you check the following path and click on the first video named "Shimmer Shimmer Video" which works but the rest dont.
http://www.fayemosshammer.com/?gallery=music-work-1
Thanks so much,
Wendy
http:// www.youtube.com/watch?v=yEwTrvILxlg&feature=shareand it should be
http:// www.youtube.com/watch?v=yEwTrvILxlgThis is this ligthbox script weakness.
