I am using the Hypershot theme and I have my home page set to the Blog page (Masonry style):
http://jerry3.doubledowndev.com/How can I update the background image for this page? Can I set it to an album like the rest of the pages? If not, a static image will do but I can't figure out how to update the background image of this page.
Any help would be greatly appreciated!
Thanks,
Adam
Have you tried setting this options in page that you selected for blog? If you set up your WP as explained here http://apollo13.eu/docs/hypershot/#!/adding_frontpage I believe it should work.
I just tested it and it works, but for some reason album controls doesn't work. I will have to check it out.
I Have fixed problem with setting up background album for blog. Update will be released in Monday.
Have a nice weekend.
