Change the OUR LATEST WORKS images on the dummy data Home Page
edited December 2013 in Superior Posts: 6
How to change the OUR LATEST WORKS images on the dummy data Home Page? I found "teasers" that should be changed. Please help. I want to use custom images here.
    Hello
    You have to edit featured images of works that are in teasers to change them.
    http://apollo13.eu/docs/superior/#!/add_new_work
  • Thank you for the help :) I would like to know, is it possible to convert Work to products?
    Yes you can do it, by changing slug of Works post type. In admin Panel it will still be Works, but your viewers will treat it as products:-)
    http://apollo13.eu/docs/superior/#!/works_menu change work slug to product, and where needed change Works to Products, for example you can do it in translation http://apollo13.eu/docs/superior/#!/translating_theme
    Hope that helps.
  • This is a great help! I am so glad that the support is excellent here. I am wondering if there is a solution to renaming the theme in the FTP directory. I tried experimenting, but the Main menu stops to function. Is there any solution to this?
    Thanks for kind words.
    I know that wordpress menu are connected to themes name, maybe also to theme directory name. I think that if you make new menu after renaming theme dir it will work.
    Give it a try:-)
    Btw. If you are happy with this theme please don't forget to rate us on ThemeForest - it helps us a lot! Thanks!
  • It worked! Thank you so much! I wish that more people will rate the product as 5 Star. It is indeed a 5 Star product for me! (Y). God Bless You!!
    Thanks a lot for your kindness:-) Have a nice day and easy using of theme.
