main page revolution slider is cutting off
edited December 2013 in Superior Posts: 10
hi,
so basically my slider is cut off and my page identifier isn't working also…how do i fix this and how would i be able to turn it off (the page identifier)
I will temp set the number of space to 120 to show you what i mean
  • It seems from what i can see to be a top bar bug...its not cut off once i disable the top bar...though when the top bar is enabled it seems to push the regular menu to far down.
  • seems to be something else actually...sorry I just realized its actually because I had the header set as with the FIX HEADER DISABLED...i cannot seem to have the header fixed or it seems to create that issue...just thought i might let you know.
    Hello
    I have checked your site, and added admin bar to my test site, and I couldn't recreate issue with header bar. I also have no idea what I could ask you to get somehow closer to recreate it:-S
