height of blogitems
edited February 2012 in Airlock Posts: 6
Is there a way to give a fixed height to the blog items overview. Now they are given a specific height according to the text and title of the blogpost. If we can give them a fixed height they will align nice and pretty.
Now there's a big contrast with the aligned layout of the portfolio items. I really think it would give some more unity to the template.
An mock-up attachment to better understand my needs.
Thanks in advance!
    Hi
    Check this page to see what we wished to achieve with blog posts http://masonry.desandro.com/
    If you don't like it you can mess with CSS, style-light.css line ~469
    add this rule, or edit existing
    .elastic .item{
    height: 300px;
    overflow: hidden;
  • Hi,
    thanks for this. Exactly my point! I was able to get it working so thumbs up.
    Now there is a small issue concerning the categories that are normally under the post. See images or website.
    Is there a way to specify how much characters the blogpost preview text on the frontpage is shown and end it with (...) if the blogpost text is to long.
    I provided 2 images. one of the current situation with some remarks. And the other one how i should be. I understand that it's not easy to perfectly align the category every time (due to length of titel, post, categorie,...), but I hope you can provide me an answer or direction.
    http://www.pilipili.be/2011/
    Thanks in advance
    1201 x 859 - 320K
    1201 x 859 - 289K
  • Quick update. I was able to fix this problem on the blog page (that displays al the blog items) by using the "read more" attribute in wordpress. But on the homepage I still have the samen issue.
    Homepage: http://www.pilipili.be/2011/
    Blogpage : http://www.pilipili.be/2011/blog/
    It looks like you solved it :-)
  • No, actually for the blogpage it is fixed when I use this workaround
    But not for the home page that shows a few blogitems.
    Any idea?
    edited March 2012 Posts: 10,970
    Wow, it was mind binder:-)
    It is pure BUG in our theme :-)
    You have three options:
    1. Use attached(updated file)
    2. Read about manual excerpts http://op111.net/67/
    3. Change excerpt length in airlock/apollo13.php, search for:
    function excerpt_length( $length ) {
    return 40;
    and change 40 to desired number of words in excerpt(comment above this function is wrong btw;-) )
    zip
    zip
    front-page.zip
    2K
