How can I reverse the order of the images in an album?
edited January 2014 in Hypershot Posts: 26
Drag and drop sorting is to difficult due to the hundreds of images in my album. I would like for the newest images I upload to display first in the album. How can this be done?
Thanks,
Matt
    Rather not possible. Maybe after releasing new version with changed system of saving album I will check is it easy to achieve.
    What I have done to overcome this limitation is a rather complicated process of generating the "images_n_videos" string containing the images for the album with a php script and insterting it via phpadmin into the db directly... If you are interested in this sort of hack let me know, I can write it down.
