Border around LayerSlider homepage
edited January 2014 in Superior Posts: 2
Hi all,
I'll try to be as specific as I can.
There is a border that surrounds the LayerSlider when used on my home page. To me, it doesn't look attractive and I would rather it be removed. I may sound silly but I cannot find a way of removing it. I cannot find any CSS relating to it or any settings. I probably haven't looked hard enough.
I don't have a live site link as I have removed the slider because of this issue. However, I have posted a screenshot for you to see.
Any help?
Thanks in advance,
Joe
    Hello Joe
    Please watch this video and stop at 0:56, there you have a list and you must select skin for your slider. Choose one that will fits you.
    You can select skin for any slider on your website. You dont have to edit any CSS code.
    I hope it helps :)
    Best Daniel
    Lead Graphic Designer
  • Many thanks, Daniel!
    That worked perfectly. Can't believe I didn't notice this drop-down.
    Thanks again,
    Joe.
