Version 1.5 issue
ronron
edited January 2014 in Hypershot Posts: 5
After updating to version 1.5 there's an odd textarea when editing or creating an album. What is the purpose of this? (See attached image).
    Hi ron
    Thanks for info.
    String "old system" is debug info I didn't remove and it will disappear if you save album - I will fix it.
    Textarea - you shouldn't see it. It is either cache or some plugin is showing all textareas. Try ctrl + f5. Anyway in this textarea are saved all of your album items, so better don't touch it;-)
    Please get back to me to tell if textarea disappeared.
  • ronron
    You're right, old_string is only shown until albums are saved the "v1.5 new way" and the textarea is gone now cache is cleared.
    Thanks for info!
