Arrows Boxes
edited January 2014 in Hypershot Posts: 13
Hello again,
i have two more questions.
1-How can i change the color or make it transparent the black box color of the arrows as show in the attached screenshot.?
2-Is possible remove the numeration next to the arrows?
Many thanks in advance
    1. Use this custom CSS
    .arrow-left, .arrow-right,
    .arrow-left:hover, .arrow-right:hover{
    background-color: transparent;
    2. Use this custom CSS
    span.slides-count {
    display: none;
    Many thanks Air! Five stars support ;)
    Just one more question, it's possible to change the colors of the arrows and the numbers if i want???
    "colors of the arrows" - they are images, so it is harder
    "numbers" - you mean numbers that you just switched off?
    Ok ;) Yes, the numbers that i think in switch of ;)
    Thanks in advance!
    Use this custom CSS
    span.slides-count span {
    color: #FF0000;
