Hi all, i need a support to manage differet type of menu on my web site i would like to have one menu that display a gallery in a way like this:
http://themes.apollo13.eu/hypershot/album/grid-2/and it could be my home page and or portfolio.
Moreover I would like to have onother menu item that display a specific set of galleries that i woul like to exclude from the previose one.
this is my website
http://man.giacintomozzetta.com/In other words i would like to have :
- Homepage that display a set of specific galleries
- Portfolio that display all my galleries
- WEB WOOF: specific galleries taht i would like to exclude from HOMEPAGE and PORTFOLIO.
Hope that everything is clear.
Colud you please help me.
With regards
Giacinto
Please help me asap
You write in wrong category again. 1. You can display either 1 gallery or all galleries on Homepage. Excluding would require some custom coding.
2. That you can achieve easily http://apollo13.eu/docs/hypershot/#!/adding_album_adding_albums_list
3. Custom coding Do you know what are you doing or just blind shooting? :-)
Anyway there are various topics here that could give you a hint how to achieve it, example:
http://support.apollo13.eu/discussion/comment/6153#Comment_6153 - it is about our newer theme, but still idea is the same:-)
I mada the same modification
a have done this in my "front-page.php" and also this in the "album-list.php" ---------------------------------------
In the reffered post you mention to do this cusrtomization anf to change the slug category. I mada as an example one of my genre "webwoof". Unfortunatelly nothing change. Note that my albums have a genre and not a category. and change 'slug_of_category' to desired category slug
Could you please help me ?
Thanks and regards
I think you are pretty close. Last part of code should look rather like this Try it, and tell me is it better now.
Although if I could id the location of line to be added in front-page.php I'm a bit more doubtfull in the album-list.php ... where should I force the genre ?
I'll try but... if you have answer it would avoid me breaking everything
Thanks Air & Gmozzet
