recent blog post
edited February 2014 in Superior Posts: 4
I would like to show My recent post on the home page, so i used the WP recent Posts tootls in the page, but doesn't retunr anything, i have 5 pots in the blog.
DO you have any issue ?
Best regards
Ludovic
PS : last version of WordPress and superior theme
    edited February 2014 Posts: 10,970
    Hello
    I think you used WP Recent posts widget instead of Recent posts. Use second one. We will probably remove WP widgets from builder by default.
  • Thanks it's Work ;)
    I'm to bad :(
    Cheers
    You asked good question that made us think about what we should change in builder:-)
    Thanks for that.
