hi, I need to edit an extra class on visual composer element for the homepage (www.culinaria .it/index.php) to align text and button about "accrediti stampa".
I add an extra class name and refer it in superior theme custom css but it doesn't work. could you help me?
thanks!
michela
Class that you added
accrediti-text-positionrefers to container of that elements. I see you wanted to set yellow color. If it was for test, then it does work, but in both case button and text, you have inline style that overwrites that rule.So you can add your css :-)
bye!
michela
