Bug in safari : little top bar exceed boxed layout
edited February 2014 in Superior Posts: 28
Their is a strange thing with the little top bar, especially on safari, it exceed beyond the boxed layout. Looks the attached screenshot (the text to the left exceed, and the social icons to the right too). I have not this problem on firefox.
Is it normal ?
Thanks a lot !
Antoine
    Hello
    I can see it on my old safari 5 on windows(almost no one use it). It probably has bug that don't implement table layout properly. What version of safari do you own?
  • 5.1.10 on my personnal computer
    but indeed on my recent computer at my work i'm on the last version of safari and there's not bug.
    But the 5.1.10 is not very old, isn't it ?
    http://en.wikipedia.org/wiki/Safari_version_history
    5 years - ages in computer terms.
  • Ah ok..
    I have the same bug on my other iMac, safari version Version 6.0.5, most recent no ? :)...
    I don't own any Mac so can't tell. Anyway safari browsers are buggy, and not so popular unless for iPad/iPhone.
    Anyway it won't be fixed due to legacy of these browsers.
    Sorry if you feel disappointed.
    With regards:-)
  • Ok i understand that. Anyway it works perfectly on the last update so it's not a problem. Thanks a lot Air !
