silenzia.com 3- vertical logo?
edited February 2014 in Hypershot Posts: 13
The logo; My logo crashes with the images and so i wonder if I can i have it vertical on the left side?
...and not have the menu on the right side lowered with it?
And when i put a vertical logo image, it messes up the reponsive layout...
Would there be an easy way to make one logo for normal layouts and one for below i pad size?
I hope so, because then this site will ROCK! :)
thanks,
Levent
    Hello again
    JackBodiless said: and not have the menu on the right side lowered with it?
    Try such thing. Go to js/script.js line ~407 and change this
    logoSizeMenu = function(){
                            menu_h = logo.parent().innerHeight();
                            a.find('div.menu-container').children().css('height', menu_h)
                                //ul > li > a
                                .children().children()
                                .css('line-height', menu_h+'px');
    to
    logoSizeMenu = function(){},
    should stop resizing menu to logo size.
    JackBodiless said: And when i put a vertical logo image, it messes up the reponsive layout...
    There is no such option. However with CSS there are various tricks you could do:
    1. after certain breakpoints hide <img> in logo and instead use background-image on <a id="logo">.
    2.resize it with CSS after certain breakpoints, eventually with use of !important. Do you need help with proper CSS?
  • Hey Air... Thanks for this man... the first bit works... hmmm except when i go on the slide view for albums... Resizes or pushes the featured images for the albums down, like the menu... so i guess... ill have to put a similar line somewhere in the script.js ?...
    please see the attached image.
    and the second... wow, boy, it is also WAY over my head :)
    I would apreciate it a lot if you could help... Would be wonderful if i could have a normal sized vertical logo in the responsive versions... Or maybe even just an S logo on the top right corner... so a second image then. Whichever is easier for you...
    If its not easy or you dont have time i can wait using a normal sized horizontal logo...
    let me know ok? Thanks a lot :)
    Levent.
    2880 x 1800 - 2M
    JackBodiless said: he first bit works... hmmm except when i go on the slide view for albums... Resizes or pushes the featured images for the albums down
    It still logo that makes your header too big which makes small places for rest of site.
    Use this CSS to make other image for logo on small screens
    @media only screen and (max-width: 650px) {
    #logo img{
    display: none;
    #logo{
    background-image: url("http://xxx.com/newlogo.png");
    height: 50px;
    width: 100px;
  • Hey man, thanks... it has changed on mobile yes, but now its repeating...
    Weird no?
    1330 x 1722 - 2M
    968 x 1554 - 1M
    I thought you know CSS to make final adjustments :-) Use this code instead
    #logo img{
    display: none;
    #logo{
    background-position: 50% 50%;
    background-repeat: no-repeat;
    height: 50px;
    width: 100px;
  • I know a little but this trick i hadnt seen before... Im going to try to understand and learn what youve done :) thanks...
