Can you please add HTML formatting to contact widget
edited March 2014 in Superior Posts: 66
For the contact widget, I would like to have my company name and address stacked on different lines so I've added
and <br> but the widget doesn't accept the formatting and it goes back to the formatting with no breaks once I click save. Can you add contact widget formatting to an upcoming update?
Thanks for your help.
    Hello
    Go to advance/widgets.php line ~775 and change
    $instance['content']= strip_tags($new_instance['content']);
    to
    $instance['content']= $new_instance['content'];
    Will be added in next version.
