I have a little problem : I want to modify the default 404 page of my website and i would know how make it ? Cause if i well undestand the 404 page isn't really a page, so how modify it ?
In fact I just want to disable the search form, the title, and add a custom text.
Do you have an idea ?
Thanks a lot,
Antoine
You can edit your file 404.php to modify the 404 template
Just as roquelage said, you can edit 404.php template, however it is also template for sitemap, so don't mess too much ;-)
Antoine
Oh, and I’m using Beach Please, not Superior. Sorry in case I’m wrong here.
If you want to change this wrong German sentence with your next update, these lines would be correct:
- Zurückgehen oder die Sitemap unten benutzen (simple version)
- Zurückgehen oder die unten stehende Sitemap zur Orientierung nutzen
( = Go back or use the sitemap below for orientation)
"Sitemap" can also be translated with "Inhaltsübersicht" or "Inhaltsangabe". But I’m not sure if every German user would appreciate such a modification.
So please don't reply but start new topic if you need any more info. And thanks for sentence ;-)
About translation check http://apollo13.eu/docs/beach/#!/translating_theme
