featured image not full width in posts
edited March 2014 in Spaceship Posts: 4
i've got problems to use the featured image with full width.
It's a bit strange because some pics work, some not ... but i can't find out why. (they got the same size and orientation etc.)
I set the sidebar to off but the pic don't go from left to right. (the sidebar is not visible but the place for it is empty)
Do you got some help for me?
    Hello
    Could you share live link?
  • Hej,
    here is the link: http://petraleitte.de/wp/blog/
    pw:spaceship
    with regards
    pandiculor said: but i can't find out why.
    I just checked and on my test page when sidebar is switched off featured images are only 560px wide. It is hard to tell why one took whole space, like it doesn't got resized version. I will get back to this later and try to find solution for you.
  • Hej, great. When do you think i can get a solution for this problem?
    with regards.
    Hello
    I have checked it was never designed to user other images there, however you can make such small modification. Go to loop.php line ~33 and change this code
    <?php a13_top_image_video( get_the_ID(), 560 ); ?>
    to:
    <?php a13_top_image_video( get_the_ID(), 560, 0, (defined('FULL_WIDTH')? 'full' : 'apollo-post-thumb')); ?>
  • Great work! i have changed it in loop-single.php, too ...
    Thanks a lot!
    regards
    Cool :-)
