hello,
I installed the update and the google maps shortcode works fine!
Very good, but there is a problem:
now on a display of a smartphone, the columns in the rows appear superimposed.
In the settings WPBakery Visual Composer plugin I checked the box control "to prevent the content elements will" overlap "one above the other (multimedia on small screens, such as furniture)," but the elements continue to be superimposed.
How can I do? to you on your phone as you see it? you tell me please?
Thanks.
Live link please with page where you see issues.
http://www.ewewood.net
Add such custom CSS, and check are you good with this: With regards.
I look forward to your update.
