<ul style="list-style-type: disc;">
Also you can attach images here, just rename it so it wont contain any fancy chars, name it for example screen.png.
the name of the file is capture2, what is the problem ? if you speak about my edit, that's why i have reupload it....
Maybe some custom CSS affected lists? Try to remove it temporary. It could also be some plugin. Hard to say without getting into console on live site.
Do you need an access? i can put live the site for a while if u're here now...
You can give same access as previously.
<ul style="list-style-type: disc;">Remove whole style attribute.
