Blog sidebar not setting
edited April 2014 in Superior Posts: 66
I have set up the blog to display a sidebar on both the single post and blog page. It is working perfectly fine on the post page but I have no sidebar on the blog page. Is there another setting I'm missing? On the blog page itself, I have the sidebar setting as Global Settings since I chose the sidebar option in the Superior Theme options. Since that didn't work, I also tried manually changing the sidebar options on the page itself to Right Sidebar and that didn't work either. How do I make the sidebar work?
Here's the page: http://www.christianbusinessacademy.com/blog
    Hello
    Have you filled blog sidebar in widgets menu? Post and blog have different sidebars.
    That solved the problem. Thanks again.
