Im having trouble with loading images onto the Slider. I can add the images to the media library, but it will not load in the slider. It worked fine until I decided to update it and now my home page is bugged up. Please tell me you still support this theme.
We don't support this theme any longer. Author of this theme is no longer working for us unfortunately. However if you explain in more details I may be able to help you.
1. What slider - Revolution Slider plugin?
2. You updated what?
3. Have any live example to see what is going on?
2. Update, meaning add new photos to site
3. website is www.fretworksdesigns.com You will notice the slider no longer works.
I appreciate any help. When I go to upload a new photo in the slider it just hangs up. I end up having to close the window.
So do you need help or it works now as it should?:-)
