Works Mobile
edited April 2014 in Beach Please Posts: 17
Hello
I am having some issues with the theme, while watching the web on a smartphone; is like the resize action does not work and the filter is active, I think this began with the latest wordpress update, I have tried this with tablets and is alright .
Do you know what could be causing this?
Thank You
Luis
    Sorry! the web is www.luiscastillo.net
    Hello
    I have just tested it on iPad and I can't confirm your issue, everything works fine. What smartphone do you use?
    I'm sorry, I found the problem,my girlfriend disable the javascript in her iPhone ¬¬' So Sorry man!
    Cool, thanks for info!
