Hi!
I've installed "WordPress Social Ring" plugin on my website and it works fine on all pages, as you can see here:
http://www.bluebirdshoes.com.br/a-marca/This plugin works thought a shortcode that I paste on the page's content field. The shortcode is [socialring]
But when I try to insert the same sort code inside the Photo Description field of an album it doesn't work...
I've also tried to insert other codes or tags inside the Photo Description field but they don't work as well.
Any clues why that happens?
Thank you very much for your attention!
It happens cause only RAW text is accepted there. It would require few changes to make it work, like in JavaScript files, PHP and CSS probably. It looks like some bigger modification. And even after this there is possibility it won't work cause of JavaScript manipulations. Can you live without it? :-)
.html()in JS file that we should be close. Do you have live link where changes could be seen?With regards.
http://www.bluebirdshoes.com.br/album/inverno2014-minimalismo-avant-garde/
Thanks again!
http://apollo13.eu/docs/spaceship/#!/modification_of_theme
