Recent works element with 1/2 + 1/2 layout
edited June 2014 in Superior Posts: 3
I have a question about the superior theme: on my homepage i use the "Recent works" element in pagebuilder and i have the row setup as 1/2 + 1/2. The problem i have is that in this setup it will not show 2 portfolio items side by side but underneath eachother. If i use the 1/1 row it will show 4 of them next to eachother so it should be possible right? or do you have some custom css how i can make this work?
hope you can help.
thanks,
Alec
Post edited by Alec on
    Recent works widget should be used only as 1/1 version cause it show many items in its row - you set this in widget settings.
