I have just updated to the newest theme and wp version.
In the previous version I put a google translation bar in the menu in the child theme. I achieved thisat that time by updating the header.php file. While now performing updates from the new theme header.php and uploading in the child folder, I don't get it work (see attached header.zip for the old version and the new one). Could you please advise me on this ?
Thanks for your answer,
Charles
I have seen your versions and I see you didn't copy all the code, that you have added, to new version - why?
I also see than in one version you add
do_action
and in other you copy whole JS code.Complete your merge, I can't do it for you.
