Hi, I downloaded adamant last week, it looks beautiful. I am not sure what the problem is, but I cant seem to get it to work correctly. Every time I i try to work in visual composer or add an element it won't work. It just says "loading" on the page with some representation of what I added underneath it. My site is dskcreative.com
I checked all plug ins to make sure I installed them, any other suggestions? I
thank you for this report, this bug will be fixed in upcomming update.
For now you should create a navigation menu (http://www.apollo13.eu/docs/adamant/#!/installation_update_after_installation) and the problem will vanish.
