I want to hide the navigation bar when in the homepage. For Ex: In Demo with Image Slideshow. I want the menu to be hidden on the First Homepage.
When you start to slide the page the navigation header menu should show up.
How can i do that ?
Mainly i want the navigation bar to be hidden when on the first screen i.e homepage. and when you slide / scroll down. it should show up.
Thanks in Advance.
RVN
in upcomming update there will be a dropping mode for header, stay tuned.
For now you can purge the 'Offset Containers' parameter in Slider settings, so it'll be full screen - navigation bar will be just below and will not be visibile.
See in your demo http://adamant.theme2.apollo13.eu/ . the nav bar is at the bottom. and when you scroll down it moves along with the next section until it reaches top.
I just dont want it to be on the Slider section as in the demo. but only when you scroll down it should be visible.
I want the slider to be whole screen without the menu.
What if i have to use the Video Full Screen instead of Images. Then how to get the nav bar hidden
For now:
-create new class in 'Custom Style' section of 'Adamant Options' like:
.full-viewport{min-height: 100vh;}
- edit row, which you want to be fullscreen, and enter 'full-viewport' into 'Extra class name' field.
should work, try another styles, play with css.
