Hello Air, the subtitles on Home are not showing. On the rest of genres it is showing. How can I do so that the subtitles show wenn all works are displayed? www.chakana.at Regards, Felix
Hi Air, I have done that and tried many other things but on home I still do not geht the subtitles. If you know of a possible problem or solution please tell me. Regards, Felix
Only that one that is explained above. I have tested in on my dev version and it made same issues. If you are sure you done everything then please send me temporary access to your WP so I could check there what is going on? Send it here on forum via private message(click on my nick and there you will find option to send message). In message please attach link to topic it applies to.
Have you defined pages for front-page and blog? I suppose this is the issue :-)
http://apollo13.eu/docs/beach/#!/adding_frontpage
Regards, Felix
www.chakana.at
Regards, Felix
Have you updated theme?
