HI, I'v put a category sidebar on a page, unfortunately this is showing all articles categories but I want that it displays only some of them. Is that possible and how? Thank you in advance Best
You will have to check in widget options, that you have used in sidebar. If it doesn't have such options, then try searching for plugin that gives such capabilities.
You can also use custom menu widget, and then create menu with links only to interesting categories:-)
