Hi!
I'm close to finishing my customization of Adamant, but I seem to have a problem I can't fix. On mobile devices and Safari, the thumbnails in the works list get real distorted, they mantain correct width, but the image height goes all the way down to the end of the page. How can I fix it?
The site is:
http://aojeda.com/Thanks!
got it, i can reproduce it, but only os old Safari 5.1.7
this bug will be fixed in few days in upcomming update.
please, can you post me more details?
what device and what browser (which version)?
It happens with Safari 5.1.10 on a Mac computer.
And for the mobile device, its an HTC Explorer with Android 2.3.5 and the built-in browser, Webkit 533.1, it also happened with a couple of Samsungs, but they were not mine and I don't remember the models. Hope it helps,
FYI - new update is available. That issue has been resolved.
Can I update it from the wordpress menu or should I download the theme again and re-customize it?
please refer to http://www.apollo13.eu/docs/adamant/#!/installation_update
