Unfortunately my contact page is not working, the page is installed alright, unfortunately does not send the email to the recipient.
I've already set the email to "BP Apollo13 Theme> Main Settings> Contact Form Settings" still does not work.
I look forward eagerly to solve this problem.
graciously
Everton
This problem often occurs on some servers, and it often ends up that you have to set something on your server about mailing.
Use some plugin for contact forms(or create new user account in WP) to see if your server is even sending mails, cause our template uses main wordpress mail function. However if it says success, then maybe something else is badly configured.
Hope that helps.
That is great, but have you tested what I asked you? It is important to test it to check what in your wordpress doesn't work. As I said this form uses same mechanism for sending mails as rest of wordpress:-)
Always when users come to forum asking about not working contact form it ends up that there is some issues with default mailing settings.
Thanks,
Wendy
I mean this procedure: With regards.
If none of plugins is working then you can't make such conclusions. But I won't explain why it is so.
akatzuki who also responded in this topic had same problem. After checking his WP installation I advised him to contact with server administrator and this what he wrote to me after: So please also follow my advise and contact your hosting provider. Tell them you have problem with sending mails from your wordpress installation.
I would love to help you, but I can not configure your server. I believe you understand it.
I suppose you still think it is our theme issue, right?
If yes then please delete it, or activate other one(other theme), and test then. If mail will be send then please come back to me and I will try to find issue. If it is still the same, and your hosting provider can't help you then I can only advise to change hosting.
Just for your information - bad configuration of mailing server is often problem in many hosting providers of our clients, unfortunately.
Hope you will resolve your problem ASAP.
And I used the mail () in PHP to send emails. I took the test and it worked perfectly, but tested the contact form and it did not work .. What is the method of sending the template?
About your question: in theme we use
wp_mail()(you can see it in advance\utilities.php line ~499) - it is the same that is used by core wordpress and other contact plugins like Contact form 7.With regards.
i have problems with the mail think, i added a new user but with no mail received.
So what can i do to fix this mailing think?
Try this "install plugin Configuring WP Mail SMTP for wordpress"
I think you could get some help on general Wordpress forums, cause now it is not theme issue but WP/server configuration.
