Cannot set up anchor links in menu
edited August 2014 in Adamant Posts: 7
Essentially the problem is that I cannot set up the menu – please refer to attached screen grabs
Have set up the anchor points in the page content as specified in the documentation
Documentation specifies an extra option on the menu setup (Navigation anchors) which allows you these to be added to a menu definition
This is not present in our implementation
We are running the latest version of Wordpress (v3.9.2)
The question there is:
How can I generate a menu option for the anchor links
