Hi there I updated the theme using the plugin listed in the documentation whoever the nav bar gets messed up, as In the colour goes and the logo disappears.
After updating theme, have you tried to change any theme option and click Save? It should recreate user.css file which is empty right now. Go to any theme settings and change anything :-) Save, then switch back to previous settings and Save again.
My website has also changed - the fonts have changed, the nav bar has gone white - it was dark before. And all the icons and fonts have changed on me.
My website is: www.smhdzines.com
Its supposed to be all that dark colour in the background and the fonts is supposed to be all caps.
Do we know why this has happened?
Cheers
Sarah
smhdzines
this is Adamant theme section and You are using Beach Please - please post your topic in correct section.
Should do it.
