Tried, but failed Probably I have put a wrong page # to CSS. Actually I would like to remove titles of every page, not just specific. Probably you have another variant for that? Here is the link for one of my page http://satinphotography.com/wp-admin/post.php?post=19&action=edit Thank you!
But this is general solution, not for specific page:-) I don't know form where you took this CSS, but in topic I have send you there is different CSS then on your page. Try again:-)
Thank you for the advise. It worked. The only thing I still see a gray rectangle on the same place where the title was. Please, see an attached print screen.
))) I will put the content/wording there. But why it should be with a padding? Is it a way to remove it? And why is this strange cross in the right top corner of the padding? It hides the whole content of the page! What is the idea behind it?
vanillababy said: I will put the content/wording there. But why it should be with a padding? Is it a way to remove it?
Padding is for esthetics and cause that is how we designed it:-) It was not intended to be empty. I could write CSS for you but there are more "Elements" that make it visible while empty. So I need to know your intentions so we wont waste time by going around solution.
vanillababy said: And why is this strange cross in the right top corner of the padding? It hides the whole content of the page! What is the idea behind it?
Did you even checked demo before buying this theme?;-)
I'm sorry, but I need you to help me with the padding. On the main page I'm going to use only background image and as you may understand padding looks terrible there. And I will probably need to remove padding from other pages too. Is it the same CSS script? May I have an option of doing it locally (on a certain page or pages) rather than globally?
Please check http://support.apollo13.eu/discussion/1236/remove-page-titles/p1 - power of forum ;-)
Thank you!
You can deactivate cross in each page settings.
Where it is useful feature?
http://bp.theme.apollo13.eu/contact/
or when you have image in backgorund and you want to show it sometimes:-)
http://bp.theme.apollo13.eu/archives/
I will let you know later on if I REALLY need to remove the padding
Thank you for your support!
29
there.With regards.
