Hi guys,
I'm having trouble finishing a website with Adamant. I can't change the favicon and the footer info, among others. In other templates has always been easy, but I can't change it in Adamant :S
Since I couldn't do it from the editor, I thought it might be 'Adamant options', but the panel is empty.
Please find attached a capture.
do you get any javascript warnings or errors in javascript console?
do you have any plugins installed other than default Adamants plugins?
I don't understand what you mean about the JAVA console, sorry
Can we fix it otherwise?
I need a temporary access to admin panel, so i could help You.
You have some big problem with server. A lot of scripts are not loaded - so a lot of functionalities are disabled.
Please try to disable all extra plugins, just leave active those which are in Adamant package and check if it helps.
What kind of problem with the server ? I'm with hostalia.com , maybe I could send them an email to see if it's their fault and if they can fix it quickly.
If not ( because their customer service is not very good ... ) , is there any other way to edit this? From PHP maybe?
