I have a couple of questions regarding this theme.
1. Shortcodes within the top head bar comment area do not seem to work. I've tried calling the shortcode with php, just placing the short code there, and I get nothing. I need to put a support form within that drop down comment area, any help would be appreciated.
2. Is it possible to remove the margins on the side of the page easily? I would like for one of my pages to allow full width for an iframed instance of another page.
Thanks in advance.
If you have more then one case to talk about then please add every case in separate topic(read more here), cause if this topic will have more then 3 answers, it will make chaos by answering to different points of first question. I believe you can imagine this :-)
Back to questions:
1. "top head bar comment area" - you have to explain me where is that:-) Screen shot/live link will be helpful.
2. If you wish to use wide layout instead of narrow then solution would be same like for Fame theme http://support.apollo13.eu/discussion/2487/only-one-page-with-wide-size#Item_6
3. In visual composer there is element named Progress Bra, check screen shot.
On question #1 I was referring to the expandable comment area. I think that question #2 has been resolved thanks to your link.
I appreciate your time and I will certainly separate my questions in the future as to avoid confusion.
To do it go to blame\advance\utilities\header.php line~84 and change: to
We will also include it in next update:-)
Kudos, awesome support.
If you are happy with this theme please don't forget to rate us on ThemeForest - it helps us a lot! Thanks! How to rate?
I have one more question. My install of blame is not showing certain themed buttons, for instance call to action block within builder, the button is just plain text and there is no CSS or image around the text. Is there an easy fix for this or would you recommend some other solution?
Do you need help with it?
Thus far I have tried ever type of button, every color, every size, and I have even tried adjusting the text thinking that I may have had too many characters in there.
Could you please send me temporary access to your WP so I could check there what is going on? Send it here on forum via private message(click on my nick and there you will find option "Send Air a Message"). In message please attach link to topic it applies to.
We are currently shipping theme with visual composer in version 4.2.3. Versions 4.3.x ended to be highly incompatible with that what was in previous version and also this breaks our modifications/extensions to this plugin. So that is why we are not upgrading it yet.
However we are working now to make it work proper with our theme.
So my advice for you is to get back to version bundled with theme, or I can help you switch of our extension for now, so visual composer will work in default mode.
Yes js_composer.zip - it is normally used for auto installation of plugin.
You don't have do anything else, just install this plugin manually.
So I did this.
1. dactivated the current version of the plugin.
2. rename js_composer folder via ftp.
3. uploaded and installed the packaged version of the plugin from the downloaded blame folder.
4. wp-admin is broken, blank pages across the board. Also, the issue with the graphical buttons is not fixed and I have also noticed that any single image module built with visual composer that is meant to be an image link isn't work as well.
I'm not certain that the visual composer plugin was causing the issue, that or the old version of the plugin is no longer compatible with the recently released version of the blame theme. Not sure, but it definitely broke the admin switching from the latest version of visual composer to the dated version.
To rectify this, I simply renamed the previously adjusted folder, and left the plugin enable. Everything (other than the buttons and links) is working as expected.
Anyway - smart move with renaming previous version:-) but I think this is what caused issue- cause now wordpress was including two plugins with definition of same functions and this results in fatal error.
If you want to test again, then copy "old" js_composer somewhere else, to you disk for example. There mustn't be two version of VC in plugins directory.
I am still not done with testing of new version of VC, but I hope to end it in few days.
Server changing is always time consuming...
Thanks for putting up with this.
I have just checked our site on small screen and it sucks big time what is happening there:-/ I hate this Visual composer. How much incompatibility there could be across two versions...
I have to stop everything I was doing and debug this crap again...
Thanks for letting me know. I will inform you as soon as we fill fix it.
Sorry for breaking your site:-(
1.2.1 should be released during weekend.
It is available on Themeforest since Sunday - you should have information about it in your wordpress panel:-)
