Login Problems
edited October 2014 in Fame Posts: 4
Hi Apollo13!
I have a problem with woocommerce sign in/login on my page. When user sign in, later he can’t log out and make another account. Only way to sign out is to delete account by admin. (The cookie issue is not activated.)
Here is the link to our website: http://www.anarosajewelry.com/
What would be wrong?
Please, help!
BR, Ida
    Hello there.
    porocnesanje said: (The cookie issue is not activated.)
    What you mean by that?
    I have created account in your site and indeed I can't logout now.
    Have you tried debugging by deactivating plugins like explained here : http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#Item_1
    Cause it looks like there is some plugin that forces login.
  • Hi
    I can't figure out what would be problem... i check the links and don't know where to find?
    BR
    Try to deactivate plugins in your page, one by one, and test if that fixed your issue. If you don't understand what I mean, then I can do it for you, but you have to be aware that during test, your site might be not fully functional.
  • Can you please be so kind and you do it for me... I'm a begginer. :) It is OK if now fully functional during test. Just fix it please. :)
    Let me know if you need anything?
    Best regards
    Then please send me temporary access to your WP so I could check there what is going on? Send it here on forum via private message(click on my nick and there you will find option "Send Air a Message"). In message please attach link to topic it applies to.
  • Hi
    I just send you the private msg. Hope u recieved it. ;)
