Hello there!
Me and my team are still setting our new website based on you Blame theme and we just run into some issues with links and images.
We need to add elements (images) to our pages which need to be clickable to link other pages but even when we set that property on the edition panel it's not working on the actual site.
Do you know why could be happening this?
I need much more details. Do you do it in wordpress editor, or in Visual composer? Can you share screen shot of your settings and link to actual page where it does not work?
I tried adding a picture through adding a text element, and linking that, and that way does work. See above link for example. There's some bug in the visual compuser.
Also, I added text elements through the visual composer, and when I try to add code in the text mode, not visual, once I click save, it strips all the new code I add.
Please use file from attached ZIP file. Put it in blame/vc_templates/.
It will fix it.
Thank you!! That worked just great!
All solved
