Social icons missing
edited November 2014 in Blame Posts: 9
I have set the social icons to white and enabled but nothing visually appears. I can run the curser over it and see a link but just can see it? Also sense I have updated to the new version I get this strange graphic in the admin with the infinity symbol repeated all over the left column.
    I have checked and I can't confirm this issue.
    1. Do you use any compression/minifcation plugins?
    2. Could you share link to your site?
  • No, on the compression plugins.
    http://chargebackhelp.com
    I have logged to your site, and for me it looks normal. I am using Firefox browser.
    What are you using?
    750 x 487 - 16K
  • Safari 8.0
  • You see the icons on the front end?
    798 x 562 - 119K
    edited December 2014 Posts: 10,970
    Yes I can see one defined by you icon. Only Safari 8 I got, is on iPad and there it is also working. Have you checked how it behaves for you on some other browser?
    I will try to set up Virtual Machine with OS X to see there if I have same issue.
    I have spend some time setting up Mac on virtual machine but it is done now:-) However I can see perfectly social icons on it. So maybe it is your local issue, or some glitch.
