I have set the social icons to white and enabled but nothing visually appears. I can run the curser over it and see a link but just can see it? Also sense I have updated to the new version I get this strange graphic in the admin with the infinity symbol repeated all over the left column.
I have checked and I can't confirm this issue.
1. Do you use any compression/minifcation plugins?
2. Could you share link to your site?
http://chargebackhelp.com
What are you using?
I will try to set up Virtual Machine with OS X to see there if I have same issue.
