hello! why not fixed DOC TYPE on IE8?
edited December 2014 in Blame Posts: 13
hello~
i'm work using blame theme.
that theme very awesome!
but i have a on issue!
my computer OS is window xp and my client too.
when i enter the my site as IE8.
every page broken.
document type and browser type not fixed.
what can i do fix?
and i attached file about that issue.
please one more check~!
thank you^^
Enjoy your life!
    didemf said: document type and browser type not fixed.
    I asked what you exactly mean by this in your previous topic. But I think you didn't answer.
    Do you mean by this that IE 8 goes to compatibility mode? If yes, then two things:
    1. Show link to you page.
    2. Have you tried deactivating plugins? There is a chance that one of your plugins is causing this.
    thanks reply^^
    so i will be checked my plugins.
    but i have a one question.
    blame theme not related any os?
    even WINDOW XP?
    that is very important for me.
    because my computer is window xp even my client.
    actually so many people still using window xp at korea.
    Hello
    There is no even one theme that is dependent on OS. Only browsers count:-)
    Why have you started third topic about same case? You should continue in first.
    Anyway I will copy your post here, and close your new topic.
    didemf said: Hello!
    i work using blame theme.
    totally that theme is awesome!
    thank you for providing that theme.
    but i have a some issue.
    when i entered my site looks like that.
    you said blame theme is support IE8.
    but when i entered my site on window xp. my site is broken like that.
    that is very important issue for me.
    how can i to do? about that.
    even i delete my plugins. but not working.
    do you have any solution?
    please if you have tell me about answer.
    please ASAP..
    I attached file about that issue. please one more check!
    thank you helping me.
    my site information:
    WP : 4.0.1
    THEME : 1.3.0.
    USING : VISUAL COMPOSER(PROVIDING YOU)
    DOMAIN : http://www.wduri07.cafe24.com
    I would love to help, but when I enter your site address http://www.wduri07.cafe24.com/ I get error "Server not found". Is this for sure correct link to your site?
    Maybe your site aren't available to view by not logged in user?
    Provide good link, and then I hope I could find what is throwing IE 8 in compatibility mode:-)
    oh...except www.
    so you will entered address just "http://wduri07.cafe24.com/"
    please one more check^^
    I have been on your site, but my IE 8, didn't go into compatibility view. Does this happen on every page or only some sub-pages show this issue?
    I see you have some custom CSS, that could throw IE 8 in compatibility view. When you experience it again, then first please try to remove all custom CSS, and refresh. If problem disappears, then we will know where to search:-)
    hello^^
    thanks reply for me.
    so i delete custom css but not working on ie8 of window xp....
    even your demo site too...
    please help me...
  • edited December 2014 Posts: 13
    EDIT: Please don't post private data without asking! This is public forum.
    please one more check..
    didemf said: so i delete custom css but not working on ie8 of window xp....
    That is strange, cause I have checked on win XP with IE 8 and it works fine, our demo and your site. I will check once again.
    Maybe when logged in there are issues.
    I have logged in, logged out visited many pages, and neither your page or our demo gave me compatibility mode in IE 8.
    Air said: I have been on your site, but my IE 8, didn't go into compatibility view. Does this happen on every page or only some sub-pages show this issue?
    Please answer me this.
    every page even menu too...
    every page...i think custom css not related...
    what should do?.... how can i solv that issue?
    and when i entered my site.
    i saw that issue message.
    please check...
    Consider using 'dppx' units, as in CSS 'dpi' means dots-per-CSS-inch, not dots-per-physical-inch, so does not correspond to the actual 'dpi' of a screen. In media query expression: print, not all, (-webkit-min-device-pixel-ratio: 1.25), (min-resolution: 120dpi)
    chrome-extension://boadgeojelhgndaghljhdicfkmllpafd/cast_sender.js Failed to load resource: net::ERR_FAILED
    chrome-extension://dliochdbjfkdbacpmhlcpmleaejidimm/cast_sender.js Failed to load resource: net::ERR_FAILED
    chrome-extension://hfaagokkkhdbgiakmmlclaapfelnkoah/cast_sender.js Failed to load resource: net::ERR_FAILED
    VM521:1 'webkitIDBKeyRange' is deprecated. Please use 'IDBKeyRange' instead.
    chrome-extension://fmfcbgogabcbclcofgocippekhfcmgfj/cast_sender.js Failed to load resource: net::ERR_FAILED
    chrome-extension://enhhojjnijigcajfphajepfemndkmdlo/cast_sender.js Failed to load resource: net::ERR_FAILED
    how can i solved that issue?..
    please one more check please...
    i will opening my site at next weekend...
    "Issues" you report are from CHROME console, and whole your topic is about IE 8, so please decide what we do here:-) Anyway those are not issues but recommendations.
    didemf said: chrome-extension://boadgeojelhgndaghljhdicfkmllpafd/cast_sender.js Failed to load resource: net::ERR_FAILED
    None of these are related to theme, and I don't have a clue why do you see it. Looks like some malwere, maybe virus/trojan?
    Back to your main issue - as I said I can't recreate it, so can't help you with it unfortunately :-(
    Is this issue with IE 8 happens on every machine you have tried or only on your computer?
    didemf said: every page even menu too...
    What does mean "menu too" - do you treat it as something else then part of every page
    in your site?:-)
    Your today post:
    didemf said: hello.
    i working use Blame Theme.
    that is awesome!
    but i have a one problem.
    that is very important issue for korean users.
    so many people still using IE8.
    when i enter first time on my site.
    IE8 browser doc type is not fixed.
    so my site is broken. even your demo site broken too.
    my client computer is window xp on service pack 3 and service pack 2.
    you wrote on themeforest site. "you support IE8 as perfectly".
    but is not perfect on window xp.
    actually i told you that issue so many time.
    but not solve that issue.
    so i attached file about that issue.
    please check file.
    and i really need solution.
    please tell me about solution.
    ASAP.
    thank you for helping me.
    As I wrote in previous post I tried many times to recreate your issue, but no matter what I did I CAN NOT make IE 8 go into compatibility mode when I am on your page. I CAN NOT hunt down what is causing IE 8 go into compatibility mode if I can't see it. There are MANY things that could cause that so, cause of what I said above, I can't give you solution as I don't know it.
    I admit that it is very strange that on your computer there is an issue, and on my there is none. But as you write, also our demo is broken for you. Maybe you have some kind of plugin in your IE, that adds something to every page, and in case of our theme it breaks IE 8? Do you have something in mind?
    When you bought theme was our demo also broken for you in IE 8?
    Every topic you started you titled "why not fixed DOC TYPE on IE8". I have checked this also and DCOTYPE is fine. Can you explain what you exactly mean by this?
    You have to answer to all my questions if you want to help me help you :-)
    hello...
    that reply is not helped me..
    i need solve IE8 issue.
    chrome issue is not necessary.
    please one more check about issue.
    http://support.apollo13.eu/discussion/2798/why-not-fixed-browser-doctypes#Item_1
    please check attached file.
    please one more check about IE8 issue.
    ASAP.
    please helping me.
    thank you.
    Oooo man....
    PLEASE ANSWER MY QUESTIONS :-)
    Also please read my answers carefully.
    Your screen shots only show that you have windows XP and compatibility mode, and this wont help us find what is causing IE 8 go into compatibility mode in your case.
