I have installed wordpress on a subdirectory and it's working fine. The menu is using anchor links and they work fine on the home page. once I'm on a subpage, the anchor links on the menu are wrong. It will attach the WordPress Address (URL) with the anchor in which the htaccess wouldn't be able to resolve it.
This is fine
http://new.silvertoad.co/#homeOn a subpage
http://new.silvertoad.co/silvertoad#homehttp://new.silvertoad.co/silvertoad is the subdirectory of wordpress
Can you please provide a solution?
I can't see anything, You page requests authorization.
If it is ok for You - please send me login credentials for admin panel. do it via private message.
http://new.silvertoad.co/graphic-design/ for example
graphic-design is another page that we created under Pages, once I'm on that page the links on the menu just won't resolve itself for the anchor links on the homepage showing at the top menu. it should read http://new.silvertoad.co/#home but it'll come up with http://new.silvertoad.co/silvertoad#home
How do I send you a private msg? is it just send you a msg?
Finally i got this working, so please expect the update very soon.
