Hi!
I would like to add below the main menu ('Photography Portfolio' www.nomadnocry.com) the name of the album being displayed. Right now it is not clear what album is being viewed by the visitor.
How could this be achieved?
Thanks for your support :-)
Kind regards
Go to single-album line ~36 and change this code to With kind regards.
Many thanks for your fast support, as always :-)
It's working good but is there a way not adding such a bar. Having it in the header just below the menu would look much better!
Also I would like to use color rgba(254,0,0,1). I tried to create a CSS for page-title class using custom CSS plugin but it doesn't work.
Kind regards,
No, it is not possible as it would require much extra work to make it behave proper.
About custom CSS there are two problems with your CSS:
1. As I said before your custom CSS plugin is weak as it adds CSS too early, and it is overwritten by main styles later. I gave you link to other plugin to use.
2. Your selector is too weak, as I can see with firebug. You should use instead this With kind regards.
Thank you for following this. I will use the CSS plugin you have introduced me instead.
Kind regards
Moreover I would like to get the name of the album in white, the background in rgba(254,0,0,1) and remove the blank space up and down of the album name in such a way the 'info-bar' size is reduced to the text size. Could you please tell me what would be the corresponding CSS code for this?
Thanks for your support!
Kind regards
Plugin is working well, you have just copied my messed CSS, without colon
aftercolor
property. Copy again my CSS which is fixed now. Sorry for this glitch.But as you now want something else, please use this instead With regards.
