"Works" portfolio slider feature is not functioning properly.
— I have setup my categories and have several works successfully posted in each section. The scroll forward & backward arrows (and exit) feature is enabled that allows users to scroll through the slider and view all works in that section.
— The problem is that this function is buggy, and only temporarily works. The first two or three Works posts will scroll properly within the carousel slider, then it will stop working. The title and sub-title will display but the featured image and text will not.
please provide an url to your website so I could check this report.
Thank You.
Can You reproduce it anytime You want?
I think I've found it.
I can reproduce the situation that You've describe, but ONLY when I press navigation arrow (next or previous) very fast, I mean before the content of previously loaded item is shown.
Can You confirm that?
Are You ok with editing theme files?
I am not a developer, so no I can't edit code.
I'm a little bit confused, this issue is tricky one.
What platform are You using? Mac? Windows?
I am on a Mac.
