Works Portfolio Carousel is Buggy
edited May 2015 in Adamant Posts: 10
"Works" portfolio slider feature is not functioning properly.
— I have setup my categories and have several works successfully posted in each section. The scroll forward & backward arrows (and exit) feature is enabled that allows users to scroll through the slider and view all works in that section.
— The problem is that this function is buggy, and only temporarily works. The first two or three Works posts will scroll properly within the carousel slider, then it will stop working. The title and sub-title will display but the featured image and text will not.
    please provide an url to your website so I could check this report.
  • This is the dev site: transfer.signalfirebranding.com
  • Please notify me when you visit my site, and if you are able to identify the problem.
    Thank You.
    I'm tyring to reproduce this error right now, and I just can't.
    Can You reproduce it anytime You want?
  • Yes. If I click on my "Works" button and then on "Identity", the first portfolio post appears, but if I click the forward arrow all content (featured image and project description text) does not appear visible. This happens in other portfolio categories as well.
    I think I've found it.
    I can reproduce the situation that You've describe, but ONLY when I press navigation arrow (next or previous) very fast, I mean before the content of previously loaded item is shown.
    Can You confirm that?
  • For me (using Firefox) and refreshed my browser, I allow the content to load and wait a few seconds, and pushing forward or backward (testing a few different categories) it works once or twice then loses the image and text every time.
    I'll run some more tests on your website.
    Are You ok with editing theme files?
  • If you can run a few tests to try and figure what is going on with it the arrows that would be really helpful. I need to get the site live but can't until I figure this portfolio issue out.
    I am not a developer, so no I can't edit code.
  • If replacing a line of code might fix it with a copy and paste I can probably handle that.
    Ok then, I'll send You (in your e-mail) a possible fix with small how_to.
    I'm a little bit confused, this issue is tricky one.
    What platform are You using? Mac? Windows?
  • you can email me at: jason@signalfirebranding.com
    I am on a Mac.
  • Please let me know when you send so I can keep an eye open for its arrival.
    The mail has been sent. ;)
  • Thank you. Hope this helps!
