Dear Support team,
My custom error pages are not taken into account anymore. While attempting to go on a page that doesn't exist it seems it is going to a 404 page proper to hypershot theme instead of mine defined in the htaccess file.
ex: www.nomadnocry.com/doesntexistpage.html
should display
www.nomadnocruy.com/404.php page
I tried to remove 404.php or replace it by mine in both theme Hypershot and hypershot_child but no change. Could you please tell me how to proceed?
Thanks and kind regards,
Charles
www.nomadnocry.com
If you replaced 404.php file in theme, then only thing that can prevent you from seeing what you want is cache, either on your server, WP or browser.
Thanks for your reply.
Indeed I don't understand, all cache has been cleared but still the same issue. Any idea? It used to work properly in the past but don't know exactly since when this problem exists...
Kind Regards,
Charles
Could you please send me temporary access(create new ADMIN account with fake e-mail) to your WP and FTP so I could check there what is going on? Send it here on forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please attach LINK(!!!) to topic it applies to.
All details in PM. Please delete my message sent to activity instead of private message by mistake!
Thx!
You can take a look at default 404.php template and try to insert all you code where now is
<?php get_template_part( 'no-content'); ?>
, it is line 17.I am not sure it will work like charm, but you can try.
