Help please. Since updating my theme, my site seems to not work as it should. If you could please goto
http://eyeondesign.co.uk you'll see a nice logo with menu either side and "Site under construction". If you click on "Home", this should take you to a page with much more content on it. In my artwork I have all the content there, but it's not allowing me to see anything below the image box with "DESIGN" in it. Also, the top menu collapses in over the log which is strange.
Any idea what's going on here. What should display is all this code:
[vc_row padding="80" a13_nava="1" a13_nava_title="230" a13_nava_timestamp="11416991504.6361"][vc_column][rev_slider_vc][vc_row_inner][vc_column_inner font_color="#ffffff" css=".vc_custom_1423138270665{padding-top: 50px !important;}"][vc_column_text]
DESIGN • WEB • PRINT • IMAGE
[/vc_column_text][vc_text_separator title="Sums up what we do..." color="custom" el_width="50" title_size="h2" second_font="1" text_color="rgba(51,51,51,0.74)" accent_color="rgba(0,0,0,0.25)" margin_top="25" margin_bottom="45"][/vc_column_inner][/vc_row_inner][vc_row_inner][vc_column_inner width="1/2"][vc_column_text]Design. It's everywhere. Today, people are so much more 'design-savvy' and that makes our job easier and more rewarding. It means we can be bolder, push the boundaries and be more creative, because the client is more on-board than before. Good design stands proud of the mediocre, and it proves it's worth, by working.
Web. Well that's everywhere too. And again, peoples expectations and understanding of 'the web' and what it can achieve are so much higher these days. And that means your website can be an powerful tool. We can help you fashion that tool into just what you need for the job.[/vc_column_text][/vc_column_inner][vc_column_inner width="1/2"][vc_column_text]Print. The art of ink on paper. But not just ink - try foils, embossings, laminates, metallic. And not just paper. Think textures, boards, fabrics, wild colours, duplex and triplex, laser cut... it's endless. The art is now mixed with some serious science. Our in-depth understanding of the process covers all facets - litho, digital, large format, exterior and exhibition.
Image. From photography, through retouching and manipulation, from computer aided design rendering and animation to web optimising, anything image-related is, quite frankly, something we excel at. It's a skill we have focused on as one of our key services. Take a look for yourself in our image section.[/vc_column_text][/vc_column_inner][/vc_row_inner][/vc_column][/vc_row][vc_row full_width="1" parallax="1" padding="160" a13_nava="1" a13_nava_title="215" a13_nava_timestamp="01417505971.3721" bg_image="288"][vc_column][vc_row_inner][vc_column_inner][vc_column_text css=".vc_custom_1423215527968{padding-bottom: 10px !important;}"]
DESIGN
[/vc_column_text][/vc_column_inner][/vc_row_inner][/vc_column][/vc_row][vc_row full_width="1" bg_color="#ffffff" padding="80" a13_nava="1" a13_nava_title="-1" a13_nava_timestamp="1417505971.3721"][vc_column][vc_row_inner][vc_column_inner][vc_column_text css=".vc_custom_1423215563955{padding-bottom: 20px !important;}"]
SOME OF OUR LATEST WORK
[/vc_column_text][/vc_column_inner][/vc_row_inner][vc_row_inner][vc_column_inner][a13_recent_works grid_columns_count="4" load_more_button="1" grid_link_target="_self" grid_layout_mode="masonry" h_margin="10" v_margin="10" collapsible_filter="1" filter_position="center" orderby="date" container_position="top" grid_teasers_count="4" grid_categories="Design"][/vc_column_inner][/vc_row_inner][/vc_column][/vc_row][vc_row full_width="1" parallax="1" padding="160" a13_nava="1" a13_nava_title="351" a13_nava_timestamp="01417505971.3721" bg_image="350"][vc_column][vc_row_inner][vc_column_inner][vc_column_text]
WEB
[/vc_column_text][/vc_column_inner][/vc_row_inner][/vc_column][/vc_row][vc_row full_width="1" bg_color="#ffffff" padding="80" a13_nava="1" a13_nava_title="362" a13_nava_timestamp="1417505971.3721"][vc_column][vc_row_inner][vc_column_inner][vc_column_text]
A FEW OF OUR SITES
[/vc_column_text][/vc_column_inner][/vc_row_inner][vc_row_inner][vc_column_inner][a13_recent_works grid_columns_count="4" load_more_button="1" grid_link_target="_self" grid_template="filtered_grid" grid_layout_mode="masonry" h_margin="10" v_margin="10" collapsible_filter="1" filter_position="center" orderby="date" container_position="top" grid_teasers_count="4" grid_categories="Office"][/vc_column_inner][/vc_row_inner][/vc_column][/vc_row][vc_row full_width="1" parallax="1" padding="160" a13_nava="1" a13_nava_title="357" a13_nava_timestamp="01417505971.3721" bg_image="350"][vc_column][vc_row_inner][vc_column_inner][vc_column_text]
PRINT
[/vc_column_text][/vc_column_inner][/vc_row_inner][/vc_column][/vc_row][vc_row full_width="1" bg_color="#0e0e0e" padding="80" a13_nava="1" a13_nava_title="-1" a13_nava_timestamp="1417505971.3721"][vc_column][vc_row_inner][vc_column_inner][vc_column_text]Understanding print is so much more than just knowing how it's done. It's our complete understanding of all forms of print that allows us to stand back and cast a well considered eye on what will suit you best.
Litho, digital, large format, vinyl, embossed, debossed, hot foiled, laser cut, heat transfer, embroidered, duplex, triplex, soft touch lamination... it's a minefield of choice. Let us guide, advise and suggest options that works best, even show you options you didn't know existed. And rely on us to ensure that you get what you choose - all to often the end result doesn't match the promise.
Your print, be it on paper, card, vehicles, clothing, banners, flags or windows needs to be consistent and perfect. We can ensure that.[/vc_column_text][/vc_column_inner][/vc_row_inner][/vc_column][/vc_row][vc_row full_width="1" parallax="1" padding="160" a13_nava="1" a13_nava_title="358" a13_nava_timestamp="01417505971.3721" bg_image="350"][vc_column][vc_row_inner][vc_column_inner][vc_column_text]
[/vc_column_text][/vc_column_inner][/vc_row_inner][/vc_column][/vc_row][vc_row full_width="1" bg_color="#ffffff" padding="80" a13_nava="1" a13_nava_title="363" a13_nava_timestamp="1417505971.3721"][vc_column][vc_row_inner][vc_column_inner][vc_column_text]
SEE THE DIFFERENCE
[/vc_column_text][/vc_column_inner][/vc_row_inner][vc_row_inner][vc_column_inner][a13_recent_works grid_columns_count="4" grid_link_target="_self" grid_template="filtered_grid" grid_layout_mode="masonry" h_margin="10" v_margin="10" collapsible_filter="1" filter_position="center" orderby="date" container_position="top" grid_teasers_count="4" grid_categories="Images"][/vc_column_inner][/vc_row_inner][/vc_column][/vc_row][vc_row full_width="1" bg_color="#3a3a3a" padding="80" a13_nava="1" a13_nava_title="125" a13_nava_timestamp="1416991149.482"][vc_column font_color="#aaaaaa"][vc_row_inner][vc_column_inner font_color="#ffffff" css=".vc_custom_1416996179540{padding-bottom: 30px !important;}"][vc_column_text]
GET IN TOUCH!
[/vc_column_text][/vc_column_inner][/vc_row_inner][vc_row_inner][vc_column_inner width="1/2"][vc_column_text]
OUR ADDRESS
Get in touch to see what we can do to make you look amazing.
01308 456195
07739 898698
mike@eyeondesign.co.uk
31 Barrack Street
Bridport
Dorset
DT6 3LX[/vc_column_text][/vc_column_inner][vc_column_inner width="1/2"][contact-form-7 id="5"][/vc_column_inner][/vc_row_inner][/vc_column][/vc_row]
It's odd, realy.
Can You give me temporary access to your websiet's admin panel? Do it only via private message, please.
I disabled all unnecessary plugins, but I suspect it's a problem between WPBakery Visual Composer and Visual Composer extend by Apollo13, neither of which I can turn off?
I turned Debug on, only to get this message on loads of sections
Notice: Undefined variable: css in /services/webpages/e/y/eyeondesign.co.uk/public/wp-content/plugins/js_composer/include/templates/shortcodes/vc_row_inner.php on line 23
What is that?
Still no nearer to fixing this issue.
This is EXACTLY the same page but with "Works List" sections
http://eyeondesign.co.uk/home/
The header doesn't work, and the page only goes down to one section. Please help, this is getting ridiculous.
We don't support this combination. Please downgrade the Visual Composer to 4.5.3 version, check if the problem persists and report issues then.
Just delete it, after that refresh admin panel and Chillout will ask You to go to plugin installer and instal it.
