Featured image in blog post is different resolution
in Xpert Posts: 13
List of ACTIVE plugins.
Only active plugins are the ones installed by the theme.
Wordpress version.
Version: 4.3.1
Theme version you are using.
Version: 1.0.1 of Xpert
Have you made any code modifications(CSS, JS, PHP)? If yes write what you changed.
I have only modified the functions page to remove double titles from my other thread.
http://support.apollo13.eu/discussion/3478/double-titles-and-taglines#latest
Any additional information that might help.
I uploaded a featured image that is 1200x800, but when I view the blog post, the featured image is 345x290 and stretched to fit so it is pixelated.
See attachments below.
Capture 1 is showing the dimensions used.
Capture 2 is showing the blog post in grid display.
Capture 3 is showing the actual blog post.
    Hi there!
    Thank You for the awesome issue description! It's not happening very often to get such detailed description!
    And thank You for this report at all - it's going to be fixed in next theme update.
    I notice that this doesn't happen on your demo website though. When is the next theme update coming?
    I found a temporary fix since this wasn't fixed in the most recent update.
    I changed line 322 in utilities.php from
    $img = xpert_make_post_image($post_id, $thumb_size);
    to
    $img = xpert_make_post_image($post_id, full);
    Lost said: I found a temporary fix since this wasn't fixed in the most recent update.
    and this is a correct solution, I'll do slightly the same in next update.
    Thanks.
