As I said before, it is not that simple. Even if I would do this it would require lot of research how to do it. Slider is generated via JavaScript from some HTML generated in single-album.php
What should happen when you share photo on slider? Should it generate some crazy link, that when clicked will take user to your site, and will scroll slider to proper image? Probably something like this if you want sharing buttons on each slide. This is difficult and no simple plugin will achieve this - this requires custom work.
If however you wish only that sharing buttons will create link to your album, and clicking it will just open this single album, then you can insert any shortcode from sharing plugins into single-album.php, and then position it with CSS.
It is important to answer such question before starting work on this :-)
Hmmm. I use the AddToAny plugin wich also allows to implement php code of the buttons. I only want on each slide (image) on the slider album a sharing option with the plugin or without. So that it is possible to share each image separately on social media.
Can you tell me where the function is for the control panels especially the "arrow down" function. So that I can do there my changes on! That would be nice!
I mean the arrow down button which hides the thumbnails from the slider album.
I need the event, html generating... Want to change the way it's normally used to. I want to make the tray button clickable with a defined url based on the shown image.
Ok, I tried to make share buttons on every image, but that seems to be to hard for me So now I redesigned the attachment.php so that this fits my needs.
Because I do not need the tray icon with the function to hide the thumbnails, I want to use that to get to the attachment.php for each image that is showing in the slider album.
I thought the "?gallery_item=image.jpg" helps me to get back from the attachment.php to the last seen image on the slider album. So that I can implement this code to the attachment.php.
CFP said: Because I do not need the tray icon with the function to hide the thumbnails, I want to use that to get to the attachment.php for each image that is showing in the slider album.
You will need to deliver array with links to attachment page to make it work. I think it would be easier to use photo description to use such links. You just could edit description for each image in Media menu.
Anyway, search in js/a13-slider.js for tray_button and tray-button to find place where it is defined and used(down arrow).
No, it is only the attachment. I want to jump by clicking on the tray icon to the attachment. And then (by clicking on the link "Back to ...) to the album but directly on the shown image from the attachment.
Thank you !
I took a look to the js where the tray function is located but for sure that is way to complicated for me to figure out where I can make changes that the tray icon is clickable.....
tray_button.on( clickEvent, album.toggleThumbsTray ); - if you know JavaScript then this should be enough for you :-) Just add your own function that will fire on click/touch.
Ok So probably it is nasty for you but... For me it's quite difficult. HTML ok, PHP quite a bit, but JS... No!
So I need advice (step by step) how to do this. The "tray button" I have changed to a different icon, ok. (take a look on my dev site) Now I need the ability that when I click on this button it will show the attachment.php of the just shown picture of the slide. Better it would be in a overlay like the simple jquery slider will do. So that it is possible just with click on the "X" to go back to the actual image in the slide.
CFP said: Only a link to the attachment.php will be fine. But if you can send me a whole thing so that the click on the tray button reads the pic id and directs direct to the attachment.php, I will love that!
I have checked code, and there is not enough details served to slider to achieve this. So as I said before - you would have to modify first what is served to slider in JSON, and after add whole thing in JS. This would be painful to describe in post here.
I think I will try to make my implementation of socials on slider in next week, and maybe I will achieve something. What you think about that?
Update on situation: I got it partly working but it needs more work still. For now it slides to proper slide after clicking "on facebook". Still some problems with proper displaying of social icons on each slide. I hope to solve it next week.
Thank you! How can I remove the "+" icon on the mobile view, so that the share buttons are always on?
And!
The share buttons uses the exact link that I need to include in my "project" so that there is a "i" (information button) button so that if someone looks at a picture in the slide view (album), the "i" button directs him directly to the picture attachment.php.
OK, but where is the question in that? What you want from me here:
CFP said: The share buttons uses the exact link that I need to include in my "project" so that there is a "i" (information button) button so that if someone looks at a picture in the slide view (album), the "i" button directs him directly to the picture attachment.php.
Ok, the share buttons (addtoany) have the exact link to the image attachment. I need the same php code that gets the link to the shown image attachment to implement this in the "tray icon" which I want to change (but I can't do JS). So that when I click on the "tray icon" I go directly to the shown image attachment.
Well you asked for PHP code, and now you are mixing it with JavaScript. Listen we are not giving lessons from coding here:-) This won't work what you are doing. You won't be able to get link to attachment in JavaScript without sending it in first place from PHP code in data array. I won't go in details what that mean, cause this beyond support help and it would took few hours to describe in forum post.
You probably should give up on this modification, sorry.
Ok, last one. Is there a way that you can tell me where in a php file in your theme I can insert the same kind of button like the tray-icon? Not in the .js file. In a php file so that the button is in the same row before the skip back, forward and play button?
No it is not possible, and would require lot of custom work(not simply code but research what is possible).
I am trying to merge the query simple gallery into your album slide view template and to get some share buttons on each image.
So if you can tell me the php file, line and the code where I can find the one for the include query simple gallery.
This doesn't seem to work: ?gallery_item=image.jpg
Like I said, all code for slider is in js/a13-slider.js so using console and basic find function you should be able to pinpoint what you need. This only works for bricks albums, slider album doesn't have such functionality - you have to build it.
If you really want to add this functionality to slider you have to dig into the code, and you will be able to find what you need.
tray_button
andtray-button
to find place where it is defined and used(down arrow).With kind regards.
Take a look e.g.: http://bit.ly/1sGMGmD
Thank you !
- if you know JavaScript then this should be enough for you :-) Just add your own function that will fire on click/touch.With kind regards.
And!
get_attachment_link($id)
where $id is id of media in WordPress library. Hope it will be helpful somehow to you.With kind regards.
tray_button.on( clickEvent, get_attachment_link($id) );
