Hello, as for wp Bakery - you get "Folder already exists" message, so please access your wp installacion via FTP, navigate to: '../wp-content/plugins' and delete 'js_composer' folder. After this you'll be able to install wp Bakery.
as for Revolution slider: you get 'Can't copy a file' message, and this is something that has to do with folder permissions (I think). To be sure I'd need to have access to your WordPress admin panel and have FTP access as well. Please provide them via private message ONLY.
Thank you for this quick and reliable support. I installed the plugins directly via FTP. The google one was not working either but a new download from the web solved also that issue. Glad I can start creating the website. If I have a question, and you need login, how can I send private message? Thx
Thx
If you are happy with this theme please don't forget to rate us on ThemeForest - it helps us a lot! Thanks! How to rate?
